Datepicker default format
1312
01-09-2025 08:56 PM
Muhammad_AzhaziqBin_Mohd_Azlan
For this datepicker format, what is the default date format being used?
Components / jimu-ui / basic / date-picker / DatePicker - Docs ⋅ Storybook
Seems like this being use for in between operation for filter widget.
Running in EXB DevEdition seems to follow my pc date format dd/mm/yyyy but when deploy it to web server it reverts back to mm/dd/yyyy
CodyPatterson
MVP Regular Contributor
Hey @Muhammad_AzhaziqBin_Mohd_Azlan
It appears the date format is mm/dd/yyyy, that at least is my view here:
The format section may be able to change this though, but I've not been able to locate the documentation just yet outlining the format section.
Cody
Laura
by MVP Regular Contributor
