Date only Field won't display in ArcGIS Experience Builder Tables
12721
22
02-14-2024 09:57 AM
ColinRichardson
Hello,
I am trying to create an experience builder application and am having issues with displaying my date fields in the tables within experience builder. My date fields have a lock by them when I open the table in Arcgis Online, map viewer, as can be seen in the photo below:
In experience builder when I create a table from the same feature, I don't even have the option to display the dates field.
The only way I could find to actually display the date field in an experience builder table was to upload the field as a date and let the program assign a time. However the time doesn't make any sense for this data as it is related to samples for days, times aren't recorded. I've tried uploading the excel file directly and changing the date field to a string data type but arcgis online will automatically assign a time and I can't assign a date only field when uploading directly because of limitations to that function.
Any help or guidance would be much appreciated been stuck on this for a bit now.
TonghuiMing
The table widget has supported these two fields in the October 2025 release.
PSRFA_GIS
If Date Only isn't supported in Charts, then maybe hold off on announcing they work in Experience Builder now?  That was a bit confusing.
YRP_GIS
I still am not able to use DATEONLY fields in the filter widget with relative date ('within the last').
It says that this enhancement was implemented in JUNE 2025, but I also agree that this is misleading and not consistent for 'widget configurations'. I recommend more details to make this more clear. I believe the enhancement is technically still required and requested!
I also agree that DateOnly field type should not have been released without matching capabilities of the 'Date Time' field type. You also cant filter by DateOnly in the HUB/Open Download UX either. Lots of missing compatibility..
ENH-000169157Add capability to access and use "Date Only" and "Time Only" fields in Experience Builder for widget configuration options
