Client labels stream layer Experience builder dev custom widget
267
01-20-2026 05:58 AM
Labels (2)
wadsonmakari
Hi all,
I am developing a custom widget by extending experience builder dev 1.16 in a disconnected environment. I am hosting the font files as described here https://community.esri.com/t5/arcgis-javascript-maps-sdk-questions/arcgis-fonts-issue/td-p/102068
I am also overriding the fontsUrl  as below
esriConfig.fontsUrl = 'https://my.host.server/fonts';
I have checked that the font files are accessible but my labels are not appearing and my console displays the message below.
It looks like the https://mydevmachine:3001/jimu-core/index.js file still has a reference to https://static.arcgis.com/fonts event though I have set it to local resource as show above. Is there another reference  to the online fonts that I may need to manually change so I can get the labels to work?
I am also checking that the fontsUrl is set to the local resource but I am still getting the above error message. Any pointers will be much appreciated.
The intention is to only label a few selected feature from the stream layer
Regards,
