Data Sources
1019
02-11-2025 03:10 AM
RodWoodford
Hi, Is there a way to globally turn off the allow export option in the data sources tab for all layers. It seems its defaulted on and you need to go over every layer individually to turn off if you don't want it to export. This can take along time if you have a lot of layers. Main issue is when building queries with the query widget. Any advice would be great.
cheers Rod
JeffreyThompson2
MVP Frequent Contributor
https://community.esri.com/t5/arcgis-experience-builder-ideas/disable-all-export-data-actions-at-onc...
No. There isn't a built-in way to turn them all off at once.* Throw some support behind this Idea, so the developers will make one.
*Take a look in the comments for a Developer Edition hack.
GIS Developer
City of Arlington, Texas
Ke_Xu
by Esri Regular Contributor
Hi @RodWoodford,
This new feature will be released at the end of February 2025 in ArcGIS Online.
Ke
RodWoodford
Excellent. Thank you.
