Hi community,
I have few questions about custom widgets on ArcGIS Enterprise AND ArcGIS Online
If i'm correct, actually here is the state :
If anyone can confirm that my 4 point are correct ? and answer to the question on the fourth point.
Good day 🙂
Everything @JeffreyThompson2 said is correct.
When you provision a custom widget you also have to add it in portal but I'll add one gotcha that has thrown many.
In the portal when you want to add the reference to the custom widget you are hosting you would normally go to new > Application, but if you get there and see this:
And do not see experience builder widget in your environment, then it likely means you do not have sufficient permissions to setup a custom widget and need a different user with a higher license level to reach it. If I remember correctly you have to have portal admin privileges to be able to set that up.
for more information see: https://www.esri.com/arcgis-blog/products/arcgis-enterprise/developers/add-experience-builder-custom...
Thanks @TimWestern and @JeffreyThompson2
Actually I used a developer edition on arcgis enterprise 11.1.
The only way where i'm confused is about adding custom widget on enterprise. Actually i never do this and my experience builder which is accessible on my enterprise work perfectly with the custom widgets that was only good placed on the right file.
I'm alone to develop experience builder, and i have full admin right.
Back to my original post : if I ask these 4 points it's to understand if I switch from Enterprise to Online, I don't want to lost the possibility to use custom widget.
I wanted to have the possibility to use only one experience builder, i don't like the principle to export all of the versions when I have a little things to change on my app, is annoying, i'm forced to changed the URL each time...
It was very sad that is not possible to use the native Online version of Experience Builder with custom widget.
And my last question : actually on enterprise i export my dev edition on the server\wwwroot.
If i'm on Online version, I have to build by myself a server (because i have no more longer the arcgis server) and recreate all path to be in the same scheme than Enterprise ? Or i can don't care and paste my zip on the desk of the web server and yolo ?
