Custom Themes for Enterprise's Experience Builder
3028
7
09-05-2023 12:29 AM
HeesuLee
Previously, we had Enterprise 10.8.1 and for the Experience builder apps, we used the Developer Version and used them by deploying the exb apps in the IIS.
We created and applied a Custom Theme to the Exb apps.
We recently upgraded to Enterprise 11.1 - and one of the key features is the ability to add a Custom Exb widget in Enterprise.
However, we realized that we cannot use a Custom Theme for the Enterprise's default ExB.
Any way to be able to use a custom Theme in the Enterprise's default ExB?
We need to use a custom Theme because we set the colors, margins, fonts etc.
Wei_Ying
Hi @HeesuLee ,
Thanks for your feedback. Could you share more information?
How do you create your custom theme? From configured manually from builder- theme editor or developed the custom theme? Where do you save?
Wei
HeesuLee
@Wei_Ying
Hi, sorry for the late reply.
We have developed a custom theme that we have put in the "arcgis-experience-builder-1.10\ArcGISExperienceBuilder\client\your-extensions\themes" directory.
Basically, we would like to use the custom Themes that we created in the Portal's default ExB apps as well.
It there any way to put Custom ExB Themes into Portal?
Wei_Ying
Hi @HeesuLee ,
Sorry that currently it is not supported to use custom theme in Portal directly. You can only use it with developer edition now. A workaround now is: you may import your apps to dev edition, apply the custom theme, and then download and deployed it to your portal.
Wei
JosephO_Connell
Hi @Wei_Ying,
Do you expect that deployment of experience builder custom themes to Portal will be available in an upcoming release?
Wei_Ying
Hi @JosephO_Connell ,
Thanks for your feedback! Unfortunately, there is not such plan yet.
But I logged it as an enhancement request inside the team, so we will investigate if we can achieve it.
Wei
MeganWatkins
Hi @Wei_Ying,
I was wondering if there was any update on deploying experience builder custom themes to portal?
Cheers,
Meg
JeffreyThompson2
MVP Frequent Contributor
@MeganWatkins It is possible to make a CSS Widget and hack a Theme into Enterprise that way.
https://community.esri.com/t5/experience-builder-tips-and-tricks/custom-fonts-and-other-css-in-arcgi...
GIS Developer
City of Arlington, Texas
