Custom Print Widget in Experience Builder Not Allowing Multiple File Format Selection - ArcGIS Enterprise 11.4
1420
03-14-2025 05:50 AM
AbiDhakal
Hello GIS friends,
I have a custom print service in ArcGIS Enterprise 11.4 and have encountered an issue while configuring it for multiple file formats. When attempting to select more than one format, I can only select a single option. In the screenshot below, you’ll see that I have selected PDF, but I would also like to be able to select additional formats so that the option to print in a variety of formats is available, which I am currently unable to do.
I would greatly appreciate any guidance or suggestions you might have regarding this issue.
Thank you so much for your time and assistance.
Abi
ShengdiZhang
Hi @AbiDhakal ,
Thanks for pointing this out. This is a known bug and will be fixed in 11.5.
Shengdi
Ankitkhanna
Hi @ShengdiZhang I am experiencing same issue on Enterprise 11.5. Can you please confirm if this has been fixed in 11.5?
Cheers,
Ankit
ShengdiZhang
Hi @Ankitkhanna ,
I tested this issue in an 11.5 environment and can no longer reproduce the bug. Could you provide a sample print service for me to take a look at?
Shengdi
Ankitkhanna
Hi @ShengdiZhang I have shared the print service URL in private direct message, please check.
Thanks, Ankit
