Crowdsource polygon and comments in a web map
856
11-20-2024 06:41 AM
MelanieNeedle
Hello, I am looking for a solution for obtaining general public feedback on land use polygons. User functionality should include ability for users to comment on polygon areas shown on a map and then also sketch in their own ideas for polygon delineation.
Would love to learn about work flows/solutions using Experience Builder, Crowdsource Report, Hub, or Survey 123?
Melanie
Ke_Xu
by Esri Regular Contributor
Hi @MelanieNeedle,
You can use Experience Builder to add a Map widget and a Survey widget. Select a feature on the map, pass it to the Survey widget, add comments, and then submit.
Ke
