Create Pin Marker in Experince Builder using URL parameters
1156
03-28-2025 05:21 AM
MartinBrandi
In WebApp Builder it is possible to display a Pin Marker  and display an associated text, by entering a coordinate set and writing a text as URL parameters. For example:
........maps.arcgis.com/apps/webappviewer/index.html?id=26fb9389f6544f7d9400024adcd4d95c&marker=552412.3201512357;6321447.4502395615;25832;;;%C3%86blevangen%2015,%209000%20Aalborg&level=12
I can't find a similar function for Experience Builder. Does anyone know how to do that?
Any help would be appreciated - thanks 🙂
Pin Marker with textPin Marker with text
Tags (1)
Ke_Xu
by Esri Regular Contributor
Hi @MartinBrandi,
This new feature has been released on ArcGIS Online in June 2025.
Please refer to the doc here.
https://doc.arcgis.com/en/experience-builder/latest/build-apps/url-parameters.htm#ESRI_SECTION1_E5A5...
sample:
https://experience.arcgis.com/experience/<AppId>#widget_1=marker:120%2C40%3B%3BmarkerLabel
Ke
Ke_Xu
Hi @MartinBrandi,
It is currently unsupported and it is in the release plan. I will keep updated with you.
Ke
MartinBrandi
Thanks, I look forward to that functionality being implemented.
Kind regards
Martin
Ke_Xu
Hi @MartinBrandi,
sample:
Ke
