Coordinate Convertion returning place name instead of address
1344
10-04-2023 10:25 AM
abureaux
MVP Frequent Contributor
The Coordinate Conversion app is returning place names in the address field.
If you type an address in and search, it replaces the address with the place name. If you click a point on the map, it only returns the place name.
Can this be changed? I need the address, not a place name.
SubaKrishnan
Hi @abureaux Currently there is no way to change it. I've submitted an enhancement request, and we will look into it proving the best solution. Thank you for reporting.
SubaKrishnan
abureaux
Thank you! This is excellent news. This will change will be a big help.
SubaKrishnan
Hi, @abureaux please check out the enhancement that went live last night. Thanks again for your valuable suggestion.
The change is at the config level as highlighted below. Once it's checked, users can see the full address along with the placename in the Address section of the widget.
