Connecting BA Infographics to map data and polygons
809
04-18-2022 08:47 AM
Tiffany_Wu
I am exploring the new Business Analyst Infographic (beta) widget in Experience Builder.  I would like the user to be able to select one or multiple polygons (census tracts) in the map that feed into the infographic specifically the "Compare" view mode.
I found that if you click on a polygon (as you would to see the pop-up), that is what populates the infographic but I would like to be able to select more than one. It works as intended in Live View but in the preview it shows the state rather than tract. Is there a workflow to connect map data to the infographic, where you can select more than one polygon? The BA infographic also does not seem to work with the Select map tool on the map itself.
Side question: Is there a way to specifically target one polygon layer for the Select map tool? My map has various polygon layers (state, county, census tract) that are visible and when selecting, it includes dozens of features as a result.
