Connect with SSO on Experience Builder application deployed in Enterprise
10776
29
10-25-2023 07:14 AM
JasonBOCQUET
Hello, I try to develop my application in Experience Builder Developer.
I I successfully deployed my application to my Portal but when I share the link to my colleagues, they can't access to my application.
I set the share parameter of the layer in the application to "Organization only" because we don't want to publish data.
So when they click on the link, a pop-up asks them to enter their username/password to access to the application. But we use SSO with our Windows session IDs. If we use it to log in and use the app, it doesn't work.
How can we configure all of this so that the login/password request is SSO?
XiaodongWang
Agree with abureaux, I think this problem is caused by the lack of clientId. Please double check that the clientId has been set on the config.json. Since the app is deployed under portal, you can try clientId 'experienceBuilder'.
JasonBOCQUET
hi @XiaodongWang now it works very well. Each time i have a new version of my exb i create a new folder on my wwwroot folder (i'm on arcgis enterprise so it's on the portal server) and add the client ID on the config.json
The only thing that is annoying me it's i'm forced to create another folder "App v1.2 > App v1.3"so the link for the user change every time. If i want to delete a folder called "App" to replace with the new version unziped with the same name my users have tons of problem : they see the old version, they forced to clear cache (and some of them doesn't know how to do that).
XiaodongWang
This problem might be caused by Service worker cache , please try steps and see if it solves the problem.
JasonBOCQUET
hi @XiaodongWang i understand your point but here is my question : i have to do this manipulation before importing a new version of my application (so copy/paste the content of the zip on the same folder) or after that ?
and i don't understand those steps :
To get better performance, here are some recommended settings for the cache header:
  • Cache index.html for a very short period such as one minute or no cache.
  • Cache the cdn folder for a long period such as one year.
what does mean "cache index.html" it's an attribute to modify ?
XiaodongWang
Download new version, unzip, copy, paste and replace the old app in the 'folder called "App" ', then
1, Rename cdn/0 to cdn/1.
2, Open index.html on your application's root folder.
  • Change <base href="./cdn/0/"/> to <base href="./cdn/1/"/> .
  • Change the buildNumber = '0' to buildNumber = '1'.
Make sure the number (CDN folder and build) is different from the previous app.
This can be set in ‘web.config’,  it does not have to be changed, just use the default value.
JasonBOCQUET
Ok, I understand more now.
But I have a last point that confused me. Each time I make an extract, the CDN of the folder and in the index.html il already "1". Sometimes I have "2", but never "0".
So if I have already "1" when I extract my ZIP, what I have to do ? change it to "0" ? or "2" ?
XiaodongWang
0 and 2 are both OK, or even any number, as long as they are not 1.
JasonBOCQUET
Ok so if I resume, the only way to not have any problem with the cache it's only to change one number ? If I do that my users do not have anymore problem with that ?
i want to be sure before to do that because the last time i'll try to paste another version in the same folder of the oldest version, i have like 30 people who called me because they don't understand why they do not see the new version.
XiaodongWang
It should resolve the problem, but I can't guarantee it with 100% certainty.
ha_hyang
I'm using the default ExP application that comes with ArcGIS Enterprise 11.3. The application with SSO, it works fine the 1st time, however, after sometimes, 15 min, the SSO timed out, the application requests to reenter the login info. Although it is enabled SSO, i have to enter the login name and pwd manually. Once it is entered, the ExP application shows the map loaded failed. I have to reload the application and lost all my filter selections.
I'm not sure if my issue is related to the original issue. but where does the time out is set?
Because my application is not the developer version, i don't have the Client If in the items config.json file.
I have updated the Max Token Expiration Minutes and maximumIdleTimeMinutes.
Do I miss any parameters in both Portal, Server configuration?
Helen
