I've tried out the new Clear Data Filters Action and it has some undesirable behavior. When I click my Button to clear the filter, all the Filter Widgets in active use just vanish from the Page. See video.
The data is unfiltered (so I guess it technically works), but only if I go into the Settings for the Action and specifically target the Datasource. The All Data option does not work on an Output Datasource.
If I was a user hitting a Clear Filters Button, I would not expect to never be able to make a new Filter. This cannot be the intended design. If it is, this needs to be redesigned, because this Action has extremely limited utility in its current form.
@Jianxia It's reproducible with a predefined clause & clear action.
@JeffreyThompson2 Thank you for reporting this issue. We will fix it in a post-UC patch.
@JeffreyThompson2, Thanks for trying this new feature. I am not able to reproduce it. Could you please share a reproducible sample?
https://experience.arcgis.com/experience/66e2013c8455408e899968be76d1129f
I've published this application with the Button in the Filter Accordion in the lower-left.
@JeffreyThompson2 The bug was fixed with the last patch. Please help verify it ~
@Suming The filters are not disappearing in my demo app.
