Change widget configuration at runtime for a custom Experience Builder widget
983
09-11-2024 11:42 PM
shoaibmomincontractlandstaffco
I have implemented the AppConfigProcessorExtension to update my widget configuration at runtime. Following is a snippet of the code that I am using. The updates I am trying to apply using setIn method are not being reflected when I output the newAppConfig in the console log for my current widget.
What is the correct way to update widget configuration using this extension point?
async process (appConfig: AppConfig) : Promise<AppConfig> {
    // Do not replace when run in builder.
    if (window.jimuConfig.isInBuilder) {
      return Promise.resolve(appConfig);
    // Clone the current app config to make it immutable
    let newAppConfig = Immutable(appConfig);
    // Find the widget in the app configuration
    const widgetConfig = newAppConfig.widgets[this.widgetId];
    //doing stuff to set searchwidgetconfiguration and usedatasources
    if (widgetConfig) {
      const updatedWidgetConfig = widgetConfig
        .setIn(['config', 'datasourceConfig'], this.searchWidgetConfig)
        .setIn(['useDataSources'], this.useDataSources);
      console.log(updatedWidgetConfig, "updatedWidgetConfig");
      newAppConfig = newAppConfig.setIn(['widgets', this.widgetId], updatedWidgetConfig);
    return Promise.resolve(newAppConfig.asMutable({ deep: true }));
Junshan_Liu
The appConfig in the process() function is mutable, so you can just update it directly, like this widgetConfig.abc=123.
