Cannot open attribute tables from layer list in map widget
939
10-06-2025 12:27 PM
HannahLegacy1
Hi Folks,
I recently upgraded all of my WAB apps to Experience Builder apps. Previously, when looking at the layer list, you could click the ellipses menu and select View in Attribute Table. There were also a host of other options in that menu. Now, in the EB app, that menu has disappeared completely. The only way to access attribute information in the table app is either by selecting it and choosing View in Table from the popup, or by building it into the table widget. The View in Table option also only allows you to see your selected feature--not the entire table.
I have quite a few layers in this app, and feel like adding every layer's table to the table widget would cause performance/loading issues. Is there any way to regain some of the functionality my users are used to?
Thanks!
ShengdiZhang
Hi @HannahLegacy1 ,
Are you using the map layers widget or the layer tool on the map?
If you use the map layers widget, there is a "Add to table" tool in the more options:
Shengdi
ShengdiZhang
Hi @HannahLegacy1 ,
Shengdi
HannahLegacy1
Hi there!
That did the trick, thank you. Did not realize there was a separate widget available for layers.
