Can Search and List Widgets Work Together?
854
02-12-2025 08:37 AM
AnthonyCastelletto
Hi Experience Builder Community,
I'm developing an Experience Builder app on Arc GIS Online (as opposed to an Enterprise installation). I'm wondering if there's any way to get the search widget to work together with the list widget. What I'm trying to do is take the results from a search and have it populate the list. As opposed to having the results show up in that popup that shows up over the search widget. As things stand, results only show up in the list if you select one of the results in the pop up.
Thanks for all you help and advice.
ShengdiZhang
Hi @AnthonyCastelletto ,
Are you using a layer source or a locator source in the search widget?
If you use a layer search source, you can configure the search widget as below:
Then the List widget, which uses the same data, will display a filtered result after the search.
If you use a locator search source, you can select the output data generated by the search in the list widget.
Please let me know if you have any other questions.
Regards,
Shengdi
AudraPayne1
Hello this still doesnt work for me I already had these parameters but my list wont filter based on what I search in the search widget
ShengdiZhang
Hello, can you share your app and data with me? My username is she10946.
