Can Layer List Widget Be Open By Default (Experience Builder)
2725
6
06-06-2024 11:14 AM
RossFindlayCOC
In ArcGIS Online Experience Builder, I want the layer List/Legend to be open on load of my app. Is there a way to do this that I am missing?
JeffreyThompson2
MVP Frequent Contributor
Not with the Layer tool built into the Map Widget, but if you build your own, it can be open by default.
https://community.esri.com/t5/experience-builder-tips-and-tricks/getting-the-function-of-the-map-lay...
GIS Developer
City of Arlington, Texas
TonghuiMing
@RossFindlayCOC In the Map Layers widget, there is an option if you turn on the legend - "Show legend for all visible layers by default":
Is this something you are looking for?
Laura
by MVP Regular Contributor
I use a section with a views navigation to keep it open upon loading.
DarylCook_mdeq
You can do it now using the Widget Controller, not the Map Layers Widget Properties.
LauraGillespie1
Thank you for posting this solution!
SergioRodriguez2
Thank you!
