Can export only 5000 records
2127
11-16-2021 07:26 PM
ErikaJimenez_Rivera1
I am designing an Experience in Experience Builder. I am using a table widget, and the export data action button is activated. It does work, however, when I try to export, a warning appears which goes "only can export up to 5000 records".
Is there any way to increase the number of records that can be exported?
JayantaPoddar
This is a known limitation in ArcGIS Experience Builder (Export is limited to 5,000 records).
Select data—ArcGIS Experience Builder | Documentation
Think Location
