Can data actions or filters support multi-step relationships across layers?
686
7
05-26-2026 11:35 PM
BrandonGuo
I have a question related to ArcGIS Experience Builder setup.
I currently have:
  • A feature service called "Park"
  • Another feature service containing:
    • an Assets layer
    • a Jobs layer
There is a one-to-many relationship between the Assets layer and the Jobs table/layer.
My goal is:
  1. User selects a park
  2. Automatically filter all assets within that park
  3. Automatically filter all jobs related to those filtered assets
The Assets layer contains Park Name/GUID fields, so I can use that for data actions or triggers. However, while the park selection correctly filters the Assets layer, the related Jobs layer does not automatically filter to only jobs associated with those assets.
There is currently no direct relationship between the Park layer and the Jobs layer.
My questions are:
  • Does Experience Builder support multi-step filtering/data actions across tables like this?
  • Or would it be better practice to move the Park layer into the same feature service and create formal relationship classes between Park and assets. Will Experience Builder honour chained relationships (Park → Assets → Jobs)?
Just trying to understand the best architecture for this workflow before restructuring the data model.
ZachBodenner
MVP Regular Contributor
Without testing, I recall having trouble daisy-chaining filters that way. However, have you tried both filtering AND selecting the Assets when a park is selected? You might be able to set up a when-selected action when Assets are selected to filter the Jobs. It also kind of depends on the widgets you're using (Table, I'm assuming here?).
Another option would depend on your ability to manipulate the schemas of the data. What is the underlying data setup here? Referenced feature classes from an Enterprise GDB? Hosted Layers? Something else? You mentioned the Assets have the Park Name in them. If you're using referenced geodatabase features, you could write an attribute rule that populates the Park Name (or GUID for that matter) from the Asset into the Job when an instance is added to that relationship. If that's an option for you I could give you examples of that code.
Happy mapping,
- Zach
BrandonGuo
Thanks, @ZachBodenner Tried selecting, not working. All data hosted on AGO. Right now, am considering auto populate park GUID from the assets parent layer through Field Map Designer.
ZachBodenner
I think that's probably your best bet (that would be the functional equivalent of an attribute rule). It's the most direct and probably the most reliable and useful from a database management perspective as well. It seems like you know your way around the Arcade to set something like that up?
Happy mapping,
- Zach
BrandonGuo
Yep, thanks to AI😀, arcade works well in Field Map.
Ke_Xu
by Esri Regular Contributor
Hi @BrandonGuo,
With the June 2026 ArcGIS Online update for ArcGIS Experience Builder, you can now configure message actions for data sources. Here is the doc https://docdev.arcgis.com/en/experience-builder/latest/configure-widgets/action-triggers.htm. This new feature will be released on ArcGIS Enterprise 12.2.
This means Experience Builder now supports chained relationships (Park → Assets → Jobs).
Here is the demo(Countries -> States -> Cites):
(view in My Videos)
Ke
BrandonGuo
This is awesome, I'll give it a try.
BrandonGuo
Hi @Ke_Xu It doesn't seem to support this type of chained relationship. Filtering a park correctly filters all playgrounds and furniture within the park. The playground and furniture layers then filter the related jobs based on those features. However, it seems that because both the playground and furniture layers are applying filter actions at the same time, the jobs and inspection results end up with zero records. (Park to assets use common field; assets to jobs use 1toM relationship). If I instead use the common Park_GUID field across all layer actions, it works correctly.
