I use automated deployments for my experiences and am trying to work on the service cache. I would rather not increment my release numbers manually and am hoping to do this in my pipeline. Has anyone automated this and be willing to share what they did?
Hi @LondonWalker I think I got why the build number in your app is not increased. The build number is saved in a file, which name is download-times.json, in the app folder. In your script, you copy the apps to the "server/apps" folder so every time, it's a fresh new app.
So, the fix should be you can change the number in the "download-times.json" before you copy the app.
Do you use this script https://developers.arcgis.com/experience-builder/guide/deployment-topics/#automated-deployments? I think the script will increase the number automatically.
Hi @LondonWalker I reverified, the build number will increase when you run the script. Could you double-check?
I am currently on number 23. I ran the script and checked again and it is still 23. Here is my yaml
trigger:
- main
jobs:
- job: Build
pool:
vmImage: ubuntu-latest
steps:
- script: curl -o exb.zip "$(curl -s 'https://downloads.arcgis.com/dms/rest/download/secured/arcgis-experience-builder-1.16.zip?f=json&folder=software%2FExperienceBuilder%2F1.16' | python3 -c "import sys, json; print(json.load(sys.stdin)['url'])")"
displayName: Download Experience Builder
env:
ARCGIS_LIB_DOWNLOADER_USERNAME: $(username)
ARCGIS_LIB_DOWNLOADER_PASSWORD: $(password)
- script: unzip -q exb.zip -d arcgis-experience-builder-1.16
displayName: Unzip Experience Builder
- script: cp -r widgets/* arcgis-experience-builder-1.16/ArcGISExperienceBuilder/client/your-extensions/widgets
displayName: Copy Custom Widgets
- script: mkdir public && cd public && mkdir apps && cd apps
workingDirectory: arcgis-experience-builder-1.16/ArcGISExperienceBuilder/server
displayName: Create App directory
- script: cp -r apps/* arcgis-experience-builder-1.16/ArcGISExperienceBuilder/server/public/apps
displayName: Copy apps
- script: npm ci
workingDirectory: arcgis-experience-builder-1.16/ArcGISExperienceBuilder/client
displayName: NPM install client folder
- script: npm ci
displayName: NPM install in server folder
- script: npm run build:prod
displayName: Build widgets
- script: node -e "require('./server/src/middlewares/dev/apps/app-download.js').zipApp('6', 'stateviewer.zip')"
displayName: Run download script
env:
NODE_ENV: production
- script: unzip -q stateviewer.zip -d stateviewer
displayName: Unzip stateviewer zip
- task: ArchiveFiles@2
inputs:
rootFolderOrFile: 'arcgis-experience-builder-1.16/ArcGISExperienceBuilder/stateviewer'
includeRootFolder: false
archiveType: 'zip'
archiveFile: '$(Build.ArtifactStagingDirectory)/stateviewer.zip'
replaceExistingArchive: true
- task: PublishBuildArtifacts@1
displayName: 'Push both compiled code (in build) and Nuget Package (in artifact) to BuildArtifact Container.'
inputs:
PathtoPublish: '$(Build.ArtifactStagingDirectory)/stateviewer.zip' #'$(Build.ArtifactStagingDirectory)'
ArtifactName: 'drop'
Thanks, this worked. I think I got confused because of this section https://developers.arcgis.com/experience-builder/guide/deployment-topics/#service-worker-cache
