Caching dev version automation
2423
6
03-19-2025 11:19 AM
LondonWalker
I use automated deployments for my experiences and am trying to work on the service cache. I would rather not increment my release numbers manually and am hoping to do this in my pipeline. Has anyone automated this and be willing to share what they did?
JunshanLiu
Hi @LondonWalker I think I got why the build number in your app is not increased. The build number is saved in a file, which name is download-times.json, in the app folder. In your script, you copy the apps to the "server/apps" folder so every time, it's a fresh new app.
So, the fix should be you can change the number in the "download-times.json" before you copy the app.
JunshanLiu
Do you use this script https://developers.arcgis.com/experience-builder/guide/deployment-topics/#automated-deployments? I think the script will increase the number automatically.
LondonWalker
I do, it does not
JunshanLiu
Hi @LondonWalker I reverified, the build number will increase when you run the script. Could you double-check?
LondonWalker
I am currently on number 23. I ran the script and checked again and it is still 23. Here is my yaml
trigger:
- main
jobs:
- job: Build
  pool:
    vmImage: ubuntu-latest
  steps:
  - script: curl -o exb.zip "$(curl -s 'https://downloads.arcgis.com/dms/rest/download/secured/arcgis-experience-builder-1.16.zip?f=json&folder=software%2FExperienceBuilder%2F1.16' | python3 -c "import sys, json; print(json.load(sys.stdin)['url'])")"
    displayName: Download Experience Builder
    env:
      ARCGIS_LIB_DOWNLOADER_USERNAME: $(username)
      ARCGIS_LIB_DOWNLOADER_PASSWORD: $(password)
  - script: unzip -q exb.zip -d arcgis-experience-builder-1.16
    displayName: Unzip Experience Builder
  - script: cp -r widgets/* arcgis-experience-builder-1.16/ArcGISExperienceBuilder/client/your-extensions/widgets
    displayName: Copy Custom Widgets
  - script: mkdir public && cd public && mkdir apps && cd apps
    workingDirectory: arcgis-experience-builder-1.16/ArcGISExperienceBuilder/server
    displayName: Create App directory
  - script: cp -r apps/* arcgis-experience-builder-1.16/ArcGISExperienceBuilder/server/public/apps
    displayName: Copy apps
  - script: npm ci
    workingDirectory: arcgis-experience-builder-1.16/ArcGISExperienceBuilder/client
    displayName: NPM install client folder
  - script: npm ci
    displayName: NPM install in server folder
  - script: npm run build:prod
    displayName: Build widgets
  - script: node -e "require('./server/src/middlewares/dev/apps/app-download.js').zipApp('6', 'stateviewer.zip')"
    displayName: Run download script
    env:
      NODE_ENV: production
  - script: unzip -q stateviewer.zip -d stateviewer
    displayName: Unzip stateviewer zip
  - task: ArchiveFiles@2
    inputs:
      rootFolderOrFile: 'arcgis-experience-builder-1.16/ArcGISExperienceBuilder/stateviewer'
      includeRootFolder: false
      archiveType: 'zip'
      archiveFile: '$(Build.ArtifactStagingDirectory)/stateviewer.zip'
      replaceExistingArchive: true
  - task: PublishBuildArtifacts@1
    displayName: 'Push both compiled code (in build) and Nuget Package (in artifact) to BuildArtifact Container.'
    inputs:
      PathtoPublish: '$(Build.ArtifactStagingDirectory)/stateviewer.zip' #'$(Build.ArtifactStagingDirectory)'
      ArtifactName: 'drop'
JunshanLiu
LondonWalker
Thanks, this worked. I think I got confused because of this section https://developers.arcgis.com/experience-builder/guide/deployment-topics/#service-worker-cache
