Business Analyst Widget Drive Times
736
08-29-2025 10:52 AM
Robin
I'm trying to create a Widget that will create drive times around a point (searchable address or drawn point). I am using the Business Analyst widget, however I don't want my users to be able to pull infographics.
However, when I disable the infographic portion of this widget, it seems the drive times won't draw.
Does anyone know a workaround or a different widget that can do this?
gis_KIWI4
MVP Regular Contributor
@Robin - Is using the Analysis Widget an acceptable solution? You can use the Generate Travel Areas tool.
Sketch an input location and run the tool.
The downside is that it stores a layer for the output.
You could possibly use this in conjunction with the Print Widget.
