Bug - Bufferdistance in meters does not yield correct results in the select widget
999
07-29-2024 05:52 AM
ECJRIJS
Dear developers,
The (powerful) select widget supports buffer selection based on data. However the widget does not give equal results between kilometers and meters (the ones I checked based on my users needs). It seems that the kilometer setting does it correct. I provided screenshots as proof for this bug.
Screenshot 1: 0.2 kilometer buffer yields the correct amount of 4 results
Screenshot 2: 200 meter buffer yields the false amount of 0 results
Ke_Xu
by Esri Regular Contributor
Hi ECJRIJS,
I could reproduce this issue. I will let you know as soon as it is fixed.
Ke
Ke_Xu
Hi ECJRIJS,
Ke
Ke_Xu
Hi @ECJRIJS,
This issue(BUG-000166931) has been fixed on November 2024 version.
Ke
