Basemap toggle button
3294
05-25-2021 04:39 AM
MatthiasDufour
I would like to know if it is possible to have a basemap toggle button in Experience (like in Instant Apps).
I know it's possible to create two identical maps with a different basemap, but managing triggers is more complex.
I also know that it is possible to add the Basemap button to the map, but the operation is different.
Is this an evolution planned in the roadmap?
jcarlson
In the Map View widget, you can add two maps.
Once added, you'll see the switcher thumbnail in the lower-left.
Clicking that switcher will toggle the maps. It's not quite the same as the basemap switcher, as this will switch out not just the basemap but any layers on the corresponding maps as well. But suppose you made a copy of your map and just changed the basemap, it would be about the same as the other basemap switcher.
Personally, I think it's a benefit that the second map is configured separately. For instance, I have certain polygon features that show up great against the light grey vector basemap, but nearly disappear against imagery. In the imagery map, I can alter the symbology of that layer to make them stand out better.
- Josh Carlson
Kendall County GIS
DavidlMason
This is exactly what I'm looking for, but I only see the Map widget. I don't even see it listed in Esri's list of basic widgets. I've seen it in Instant Apps and was hoping to put it in an Experience Builder template also.
Where do I find it?
MatthiasDufour
Thank you for your reply.
I'm aware of this possibility, but I'm looking to use the Filter widget for map data and this widget only works for one map.
This is the reason for my question.
jcarlson
You should post an idea about getting the Filter widget to act against multiple data sources. I'd upvote it!
- Josh Carlson
Kendall County GIS
