Asset Still Selected in Map after Submitting Survey in Survey Widget
596
08-02-2023 08:15 AM
JasminePrater
We have a Map widget connected to a Survey widget and once a survey is submitted for that asset and the asset that was selected in the map feature remains selected.  It does not unselect that asset when reloading the page or when refreshing the survey automatically.  This is causing our crew to create multiple inspections for different assets on one asset and I have to manually inspect and investigate duplicate records to see if this is the reason.  Is there a way to set it so the feature selected in the map is unselected when the survey refreshes or the user refreshes the page?
