ArcGIS Experience Builder SDK - Connect to Enterprise Data / Client ID
2005
6
11-30-2023 02:55 PM
CW-GIS
How do you get a Client ID for Enterprise to use for Experience Builder SDK?
Because when you login to developers you have to use an AGOL Organizational account. So the Client ID will be tied to that and not to our Enterprise.
Grant-S-Carroll
There is a section in the help that shows how to create a client id for ArcGIS Enterprise.
https://developers.arcgis.com/experience-builder/guide/install-guide/#create-client-id-using-arcgis-...
CW-GIS
I saw that, but Step 6 under Create Client ID using ArcGIS Online or ArcGIS Enterprise doesn't exist from what I see.
After I create the application in Portal, it takes me to the item page and the only options are Overview or Settings. There is no Manage.
If I go to settings, there is an button for App Registration: Registered Info. That gives me an App ID, but that doesn't work in experience builder.
Grant-S-Carroll
What version of ArcGIS Enterprise are you using?  Whats the error you recieve when you try and use the App ID from the application you have created?
Its looks like the instructions have been done using AGOL. Enterprise is slightly different, eg no manage button.
CW-GIS
We are on 11.1
This is the error when I put in the App ID
CW-GIS
I tried it again, this time it's just goes to a blank screen, no error message
Grant-S-Carroll
Hmmmm, ok.
This what I have for reference. Note: using 11.1 as well.
And from the item setting page using the AppID
It could be being caused maybe by a CORS issue, if your portal has been restricted to certain domains. You can add in domains within the security settings of portal. If you look at the developer console of your browser, are there any errors appearing when you get the blank screen?
