API Key for arcgis experience builder and dash board
614
01-12-2026 06:33 AM
vijaybadugu
I would like to set up api  key for  arcgis experience builder and dash board in arcgis online ? Could you please tell us how to configure it on these apps ?
VenkataKondepati
Honored Contributor
Hi @vijaybadugu,
As per my understanding, API key for Experience Builder or Dashboard is not supported yet.
Please refer to the documentation below.
Introduction to API key authentication | Documentation | Esri Developer
There is an idea submitted below.
Support for API Keys authentication in Experience ... - Esri Community
You can use the video below for learning.
https://www.youtube.com/watch?v=h68pd449wd4
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
vijaybadugu
Thanks for your response. Which one i need to use to create an api key (ArcGIS Online or Platform) going forward ? ArcGIS Online is credit based consumption and platform is pay as you go.
VenkataKondepati
Honored Contributor
It depends on your use case.
If you are using internal company tools, ArcGIS Online is a good choice, but if you are building commercial SaaS products, ArcGIS Platform is a better choice.
I hope this helps and let me know.
Regards,
Venkat
