Allow users to change Symbology field in Experience Builder
3350
04-25-2024 10:28 PM
PurakShrestha
Hi
I have a a feature layer with many fields in Experience Builder.
I would like the user to be able to select the field that the map symbology will be based on, a bit like changing Symbology field in ArcGIS Pro. And I need the symbology type to be Graduated.
Is there a widget that can do this or would it need to be a custom solution? If custom, can you point me in the right direction.
Kind regards
Tags (1)
JeffreyThompson2
MVP Frequent Contributor
There are no options within Experience Builder that allows the end-user to change symbology. You will need to make a custom widget.
Custom widgets in Experience Builder do have access to the full power of the Javascript API. This page is a good place to start learning about variable symbology in the API.
GIS Developer
City of Arlington, Texas
