AGOL Filter widget - inbuilt search causing dropdown list to reset
838
10-22-2024 10:16 PM
NBC
Hi all,
Has anyone else found when setting up a filter widget using the 'is any of' option in the expression builder on a text attribute producing a dropdown list of tick boxes,  that if you enter a search term in the little search box directly above the tick box list and select a tick box, it will remove the search filter despite the search term remaining in the box? I would expect the search filter list to remain in place whilst the search term is in the box.
I've tested this with small and large lists and on Chrome and Edge and seems to be the same issue.
Is anyone aware of this being a known bug or even finding this an issue?
Here's what I mean:
Image 1 - initial dropdown tick box list:
Image 2 - search term added, list filters by search term:
Image 3 - tick box selected, but the list 'unfilters' itself:
Any feedback would be great thanks for reading!
Regards
Andrew
NicoleJohnson
MVP
I just tested this in Enterprise 11.2, and I'm seeing the same thing, but only when the filter is turned on to start with. If I don't turn on the filter, it lets me keep checking boxes until I'm ready to turn it on.
NBC
Thanks @NicoleJohnson I hadn’t seen that so at least there’s  a workaround until the issue is ironed out.
