Adding button for next page in Header
863
03-05-2025 02:26 PM
BEN12345
I sit possible to put a next page button in the header but each page having different links to pages. i.e Page one links to page two etc. Currently I am changing the button to connect from page 1 to 2 but this sets the link for all pages because its in the header. Is there any way to combat this?
IssyAmis
Hi @BEN12345
As far as I can tell, there isn't currently a way to configure the header to be different for each of your pages in Experience Builder. Therefore, if the header is enabled then it will use the same button widget and configuration for each page. Perhaps you could raise this as an idea in the Esri Community ideas section?
To combat this, you could look into used a fixed panel for the header instead - this way you could use a different button for each page. Let me know if you have any questions about this.
https://doc.arcgis.com/en/experience-builder/latest/build-apps/add-a-page.htm#:~:text=The%20header%2....
Thanks!
Issy
