Adding all layers to the Table Widget
5550
11
03-13-2023 08:56 AM
Calvin_Wong
Is there a way to simply add all layers to the table widget in Experience Builder? I want to mimic the experience of the Attribute Table in WebAppBuilder, and it would be helpful to not have to add 30+ layers individually to the table widget.
Thanks
Shen_Zhang
Hi everyone, a quick update bulk import is now supported in the table. You can select web maps, web scenes and group items to import all the applicable layers.
Shen Zhang
Shen_Zhang
Hi @Calvin_Wong
Currently if you want to add sheet to table widget you have to go layer by layer. In Web AppBuilder only one web map can be added and the table is associated with the table - while in Experience builder table can connects to multiple data sources, not only web maps.
However I think your idea is somehow valid and could simplify app building process if a table has a strong correlation to a certain web map. Feel free to raise an idea in the Ideas channel or go through Esri Support, we can help evaluate the enhancement possibility based on the general feedback along the way. Thanks!
Shen Zhang
Blevins_Mark
This really needs to be added to EB functionality. Just a way to sync the table with a map would be sufficient. Going through and manually adding each attribute table to the widget is just, ugh...
MatthewMaloney
Yeah some way to add in bulk seems necessary. I have maps with literally hundreds of layers and adding them individually to the table widget is a painful waste of time.
Shen_Zhang
Shen Zhang
AlexAurica
Good day Shen, would you happen to know what versions of Experience Builder have this quick update bulk import for the table widget? And where it would be located as an option? I'm on EXB through Enterprise 11.3 (the latest version as far as I know), and I'm struggling to find it ahead of importing 100+ layers.
Shen_Zhang
Hi Alex, bulk import is currently in ArcGIS Online (since June 2024 update) and will be available for the upcoming Enterprise 11.4.
To bulk import all the layers to a table, simply click on the web map - all the layers will be imported. It's pretty straightforward so there's no option for this function.
Shen Zhang
AlexAurica
Good morning and thank you Shen,
I see the issue then - it's not in 11.3. I suppose I will check against
AGOL. Appreciate your help!
-Alex
mohannainar1
1.16 its is possible
mohannainar1
any idea how to display client side feature layer into table widget ?
