Adding a join in Experience builder
2006
04-06-2022 01:33 AM
RyanDavidson1
Hi!
I have added a feature layer to a map in Experience Builder and now i'm wondering if it's possible to add a join to the feature layer? When i click on the data tab and then open the settings for the feature layer i can see the attribute table for the layer but no obvious way to join another table to it. It would be super handy to be able to do this as this is the method i use in Pro and Map to avoid manually adding fields to the attribute table which is time consuming.
Zoggo
I'm facing the same problem.
