Added widgets don't show in the insert widget pane
883
06-02-2023 05:09 AM
KennethLindhardt1
Hi, I'm exploring how to create or modify a widget in Experience builder Dev. It is running on my localhost
I've added theSDK Resources in my your-extensions --> widgets.
I took for example the editor and pulled it out of the widgets folder I took the simple  and changed the manifest title, and the title and the _widgetLabel
Restarted the server, but nothing changes in the experience builder GUI.
I even tried to modify the Simple widget, name and label and recreated the Building your first widget video on youtube. I restarted the machine and such, but nothing really make it appear in the Insert widget pane in experience builder. The server is running from the same main folder that also includes the client folder. So what am I missing here, I can't see where it goes wrong going through the ducumentation.
KennethLindhardt1
Don't know exactly what went wrong. I reinstalled the experience builder sdk since I had a lot of errors on the cross-env. After installing the packages a couple of times on the client, it finally went through and deployed my widgets 🙂
