Add Messages to Analysis Widget
4779
8
07-19-2024 06:59 AM
taylorrobinfemadhsgovRobin
I am trying to add messages to the Analysis widget in AGOL Experience Builder that is using a Geoprocessing Service. Previously in Web AppBuilder, if you included arcpy.AddMessage in your script and set the message level to "info" when publishing, that message would show up in the Output box in the Geoprocessing Widget like a print statement. I have not been able to replicate this in Experience Builder's Analysis widget. When I run a tool, it just runs with no messages. The messages are useful for debugging and just letting users know where in the process the script is. For longer running scripts this is especially helpful. Am I missing something or is this functionality not available?
Wei_Ying
@taylorrobinfemadhsgovRobin ,
Thanks for your feedback. Would you be able to share with us a reproducible gp service?
Wei
Any GP service with arcpy.AddMessage("Messages....") in the code would be an example. I cannot share one of ours publicly.
Wei_Ying
Thank you! We are working on this issue now.
sxw_eaglegis
Yes looks like at the moment only warning and error messages are getting logged in the widget.
I noticed using the python logging module and set stream output to sys.stderr works, but logs as a warning message e.g.
import logging
logging.basicConfig(level=logging.INFO, stream=sys.stderr, format='%(asctime)s - %(levelname)s - %(message)s')
logging.info("This is an info message")
mhaley_stone_env
I am also seeing this bug in the analysis widget. Here is an example (I cannot share the GP script directly) but in the Web App panel I can see all my messages guiding the user as to what is happening in the tool. With the XB analysis widget I can only see the single warning message with no others.
Wei_Ying
Thanks all for your feedback!
We are working on enhancing the Analysis widget to customize the message level. It will be available for the coming November release.
NourSalamJMT
@Wei_Ying hello! I checked the Analysis widget documentation and can see that message level info capability is indeed now available in ArcGIS Online. Would it be possible to let us know when it will be made available in ArcGIS Enterprise? It was not included in 11.3 nor in 11.4 releases based on documentation.
Wei_Ying
Hi @NourSalamJMT  This feature is available in ArcGIS Online, for Enterprise, it would be 11.5. Thanks!
