Add attachment to standalone table using edit widget
3275
6
01-02-2024 11:11 PM
HanliePetoors
I'm working in AGOL with a page that has a table widget and an edit widget. Both are linked to the same standalone table in a feature service.
I use the table widget to select a record, which is then displayed in the edit widget where I can edit the record. I do it like this because I also need to add new records, which I can't do with just the table widget as far as I can tell.
The table has attachments enabled and I can add these in ArcGIS Pro but not in the edit widget in Experience Builder.
Does anybody know if adding attachments to records in a standalone table is possible in Experience Builder?
Thanks
Hanlie
AlixVezina
Hi @HanliePetoors ,
Right now there is a known limitation in the Edit widget where editing a layer in Attribute only mode does not support attachments. We apologize for this inconvenience.
AlixVezina
Hi @HanliePetoors ,
HanliePetoors
Hi Alix,
Thanks for the reply and the confirmation.
Regards
Hanlie
Sepa-Rated
Hey, if you are desperate, you can edit table attachments with the Instant App - Manager (Beta).
So set that up and just use an embed to bring it into an experience page. Of course you can't seem to add a new record. So use your current setup to add new and edit, then switch pages to your embed to add attachments.
Again, if you're desperate 😛 its not a pretty solution but technically it works.
HanliePetoors
Thanks for the reply 🙂
I may have to resort to something like this if I can't persuade the client to capture spatial points rather.
Regards
Hanlie
Kuyler_JonesCivil
The Sidebar Instant App seems to have this functionality. Still missing from Experience Builder.
Edit: Not for standalone tables, but Sidebar works well with related records.
HanliePetoors
Good to know, thanks.
