Add address next to pin on map using Search Widget
1077
10-03-2024 11:50 AM
TimHayes3
Using the Search Widget, is there a way to add the address (example, 123 Main St) next to the pin on the map after the address has been entered into the Search Box? or at least have a pop-up next to the point/pin icon?
Ke_Xu
by Esri Regular Contributor
Hi @TimHayes3,
After November 2024 release, search results can have popups.
Configure the following message action for the Search widget: Records created - Map - Show on map. Ensure the 'Set as operational layers' option is enabled in the Action settings window.
If the search widget selects "Interact with a Map widget" in Content - Source, this action will be automatically added.
Ke
Ke_Xu
Hi @TimHayes3,
Ke
