Add a CSV, XLS, Spreadsheet etc. to display Polygons
734
02-06-2025 03:04 AM
CMcDonald
is it possible within ArcGIS Experience Builder to have a map which contains a layer with Polygons displaying for example "zones".  The attributes within the Polygons would contain something like a zone code i.e. Zone 1, Zone 2 etc.
Can a user (viewer type account) then add in some sort of spreadsheet in either CSV, XLS, XLSX format etc. that contains some of the zones so that only matching polygons are highlighted or even better only matching polygons are displayed?
> All 'zones'
> Add CSV, XLS etc with a list of zones
> Display only matching zones
Thanks in advance
DanielFox1
Hi @CMcDonald
You could attempt with the add data widget but this is something you might be better configuring and joining data before involving the experience builder app.
Data Centric Widgets
To be clear a Viewer has limited permissions
"Viewer—View items such as maps, apps, demographics, and elevation analysis layers that have been shared by other ArcGIS users. Those assigned the Viewer role can join groups owned by the organization, as well as use geocoding, geosearch, and network analysis (routing and directions). Members assigned the Viewer role cannot create or share content or perform analysis or data enrichment. The Viewer role is compatible with all user types."
https://doc.arcgis.com/en/arcgis-online/administer/member-roles.htm
