I am working with 4 cards arranged in a grid pattern. How do I get rid of the center gap?
It seems there is a predefined background grid the cards are snapping too, however there is no way to adjust the cards to be flush with each other. Or add a line in the center to use as a guide. This project is being designed for mobile, so the 10ish pixel gap is space I would like to use
Had the pleasure of getting the solution from Jianxia herself and wanted to share with everyone. Set the Gap to 0 px on your block / row. Huge thank you Jianxia
