Accessing Map Widget (WebMap) Reference in a Custom Widget in Experience Builder
4666
12
06-23-2025 01:10 AM
MirzaMuhammadAhsanAli
I am working on experience builder, migrating a web app of Web App Builder into it from scratch. In WAB we have a map reference in this.map so that we can apply definationexpressions. Now in Experience builder how can i get the reference of the map in custom widget. I have used map widget and attached webmap on it.
@Sage
Can anybody help me to get the reference of the map in custom widget?
TimWestern
MVP Regular Contributor
@MirzaMuhammadAhsanAli The React/Exb paradigm takes a bit of time to get used to no worries.  We've all had things we have learned through the process that at one time might seem obvious to someone else.
Let us know if you encounter any additional challenges.
TimWestern
I will need a little time to look at this, but you have your files named .jsx (ie JSX) as opposed to .tsx (TSX)?
I think Experience builder uses Typescript so you may prefere the TSX extension for any UI component and pure libraries as .ts
check your config.json file if it exists, and make sure its not conflicting with the manifest.json  for example, make sure it doesn't override or strip out useMapWidgetIds.
You can also use logging of the props and the props.config in Settings.tsx to see if it even receives useMapWidgetIds on render.
Eg:
console.log("Settings panel rendered", props);
In the experience, you'll need to (if you haven't already done so) add a Map Widget dragged onto the page (and a map source set in the settings)
You also need the custom widget dragged onto the page and then once its there if you aren't in 'live mode' you should be able to click on it to see and sett the settings you setup.  I need to review the code with a bit more detail than I have time for today to give additional thoughts.
@TimWestern , I mistakenly wrote jsx instead of tsx, but the files have extensions tsx as shown in the screenshots in my previous response.
I will also try your recommendation.
could you please share your email address so that i can share my code(files) with you?
