Search Widget - Add Style Settings for the Search Button
3237
7
01-03-2022 03:00 PM
Status: Open
Labels (2)
DaveFullerton
To reach our organizations branding standards, we set colors in the theme and had to manually override the styles for all of the buttons in our ExB applications. When I added the new Search widget, I saw no way to change the background color or hover color of the search button. Style settings for this would be much appreciated.
7 Comments
Ade_Bruijn
Here a likewise problem with the search widget. Although I can change the background by changing the theme with custom colors I can't find a way to change the icon color.
AndreasEugster
We are also struggling with the search widget. In our case, the search widget is placed in an organization-specific colored header where a theme-style for all the other buttons/widgets colors (or vice versa) would not match.
Alison_Mynsberge
This also affects our clients.  We need the ability to either set light/dark themes for all the map-linked default widgets in EB or customize them as the widget controller widgets can be, because it would be helpful for these to match.
Alison_Mynsberge
Alternatively, if all the map-linked default widgets (search, layer/legend combo, etc.) were available in the widget controller where they'd follow the style settings set for a given theme, that could also suffice.
JeffLegato1
The default blue stands out like a sore thumb and makes what would otherwise be a coordinated appearance look just wrong.
RebeccaWatson1
You can control this by changing your theme primary colour - doesn't help if you want it white but works in some cases.
AaronKoelker
This would help us as well, but I would expand it to include all widgets that are affected by the light/dark theme setting (filter dropdowns, table widgets, search bars, etc.). Even just being able to toggle between light and dark themes for individual widgets, rather than the current all or nothing approach would be very beneficial. As it is now, it can be very limiting and difficult to work with.
