Recognize Expression Fields inside Near Me Widget
608
10-31-2024 02:51 PM
Status: Open
SteveCole
Honored Contributor
Trying to develop an EB app that will summarize census data based on the user's area of interest. Many census tables will break out the information based on multiple value ranges (3 age range classes, for example). On the web map side, this is easy since you can just create an expression using Arcade to sum up multiple field values as one.
Unfortunately, if you do things this way (instead of adding a new calculated field) that expression field is not an option inside the Near Me widget's summarize section as one of the field choices. It would be a tremendous help if it was an option to include calculated expression fields in this part of the Near Me widget.
