Provide 'Overview Map' widget in Experience Builder
4440
10
02-29-2024 05:44 AM
Status: Open
Labels (2)
GeeteshSingh07
Please provide 'Overview Map' widget in ArcGIS Experience Builder, as it was in Web AppBuilder.
https://doc.arcgis.com/en/web-appbuilder/latest/create-apps/widget-overview-map.htm
10 Comments
Yogesh_Chavan
Nice idea @GeeteshSingh07.
Not sure how ESRI missed this for so long?
JeffreyThompson2
On the roadmap for Q4 2024.
GeeteshSingh07
@Yogesh_Chavan it was logged as enhancement (ENH-000159699) as well, still not included in ExB yet.
GeeteshSingh07
Thank you @JeffreyThompson2 for sharing the roadmap. This is for ArcGIS Online, right?
Once release in AGOL, then in next quarter it will be rolled out it Portal & Dev Edition?
JeffreyThompson2
@GeeteshSingh07 ArcGIS Online gets all the updates first. Then, the new version of Developer Edition comes out about a month later. ArcGIS Enterprise gets new features with the new version following the ArcGIS Online release. You will need to upgrade to the new version of Enterprise to see the updates and sometimes it takes two update cycles to match full parity with the Online version. So if Enterprise 11.3 is the latest version when the Overview Map goes into ArcGIS Online, expect to see it in Enterprise 11.4 or 11.5.
GeeteshSingh07
@JeffreyThompson2, thank you so much for the explanation. Really appreciate it.
JustinH
@GeeteshSingh07 There is a Show Map Extent Feature (not widget) in Experience Builder. In the Map widget, you an toggle on the "Overview Map" in the map widget Settings. This creates a button on your map widget to see the Overview Map. The only thing I would like for this to improve on is a little more freedom to customize this feature.
GeeteshSingh07
@JustinH thank you for the comment. Yes, ArcGIS Online ExB now has this Overview Map feature. I guess it was introduced in June'24 update. Even Developer addition 1.15 has this feature now. We are still waiting for this feature to be added in ArcGIS Enterprise.
Yes, I agree there must be option to customize it..
shodge_fsu
Yes - Developer 1.15 edition has the overview map now, however it shows up as a tiny arrow icon in the lower right corner where about 1% of my users will ever see. There does NOT appear to be any way for you to have it open by default.  This makes this new feature basically useless until there is an option to have it open by default.
KevinMayall
This overview map implementation is not a widget.  It is a tool in the map widget.  So it is 0% customizable.
I tried placing a second map widget on the screen.  The best I could do was turn off all of the tools on the second map (overview) widget, restrict its scale range to show the whole geographic area, and then add a trigger on the first (big) map widget to change the extent of the second map widget when the first map's extent changes.  I could not come up with a way to show the rectangle of the first map on the second map.
