Link views navigation to sidebar widget
377
01-11-2024 06:34 AM
Status: Open
Laura
by MVP Regular Contributor
I have to put sections within sidebars in order to get the views to connect. The issue is that sections do not collapse and in order to get that functionality it all has to be within a side bar, but then the views do not connect to just the sidebar. It starts to get messy when creating and moving things around and I wish the widgets just connected more freely.
1 Comment
TomDuncanGIS
@Laura, not sure if the issue described is the same as I posted awhile ago.
https://community.esri.com/t5/arcgis-experience-builder-ideas/add-web-appbuilder-classic-tab-theme-t...
The hack I worked out is functional, but can’t get the panels to collapse as you mentioned.
I also submitted an idea to design the Feature Info widget to be able to display attributes from more than one feature layer at a time.
https://community.esri.com/t5/arcgis-experience-builder-ideas/configure-feature-info-widget-to-displ...
Cheers!
