The Select widget, when 'Interact with a Map widget' is selected, will list all layers from the map, without group layers. When a map has many layers, and in some case different layers used in different groups can have the same name, this list gets messy.
The configuration panel gives the possibility to make individual layers not selectable but the possibility to keep the group layer stucture is missing.
Hi @Thomas1 ,
I agree - I have a web map with many layers and they are grouped to make them easier to find. If the Select widget respected those groups it would be far more useful.
Related issue with layer groups in the Swipe widget: https://community.esri.com/t5/arcgis-experience-builder-ideas/swipe-widget-with-group-layers-needs-t...
Same problem here:
