Experience Builder- Edit Widget- Ability to create required fields
3186
08-08-2022 11:46 AM
Status: Open
Labels (2)
Amanda__Huber
MVP Regular Contributor
Hello Experience Builder Team,
Please create a way to manage field requirements through the Edit Widget. Currently there is no way to make fields required/not required. This will allow admins to ensure data quality.
EB Edit Widget Field Configuration- There is no way to make certain fields required
Thank you,
Amanda Huber
4 Comments
MavTucker_CoMo
Please! The "created" feature currently disappears (doesn't create) without warning if not all fields are filled out, and instructing users to add placeholder data messes with SQL queries and views already created and in use elsewhere.
Additionally, date fields require a time even when it is turned off in the pop-up.
PeterKT
We have 10.8.1 Enterprise and are still using the old web map.   No matter what I do in the fields configuration it makes no difference.  I just suspect the old web map is the cause.  Hoping 10.9.1 upgrade will fix this.
Compulsory fields and maybe some of the Field Maps functionality with semi-smart forms would be good.
Why would I want to edit ObjectID?!?! 🤔 👇
Jennifer_Parmeley
Has there been any movement or feedback on this one?
I use Boolean fields in our data sets to display map points.
Is this facility active? (yes/no) This allows users to remove a point from a map and prevents accidental deletion.
This appears to be available if you use a form.
Marc_Patti
Also interested to see if there has been any movement on this. I'm glad that we can still make certain fields required using the smart forms in Field Maps, but this really seems like a feature that should be configurable in Experience Builder itself.
