Here is the ask: Build a dashbaord that enables the user to run spatial & attribute queries, and have the corresponding map, data tables, graphs and charts update according to the records returned from the spatial query.
Problem: Currently, data *selections* are not supported via trigger actions in the query widget (this has been confirmed by Esri techincal support). The query widget has the capability to highlight records within the spatial query, but they are not actually selected. If they were to be selected, then action triggers in the Map widget would allow for graphs and charts to update on the fly.
Business justification:
The current workaround takes multiple steps and requires 3 widgets:
1. Using the filter widget, set any attribute filters to refine data
2. Using the query widget or the draw widget, drop a point/buffer on the map to visualize a radius ring
3. Using the selection tool in the map widget, match the circular selection as closely as possible to the radius ring on the map
If the enhancement to allow the query filter to make an actual selection on features, the process would take 1 step and 1 widget:
1. Using the (updated) query widget, set all attribute and spatial query parameters, click "apply" to have features that meet these criteria selected on the map, and the corresponding graphics/tables would be update via map triggers
If anyone knows of a better existing work around, please let me know! Happy to discuss further.
Chris
*In the snip below, you can see that the query filter has run a spatial query of 3 miles on a point dataset and it highlight the features, however there are actuall zero records selected
Yes, this is related to an idea I posted:
This is a major limitation. We have been told by our local Esri reps that we shouldn't be writing custom applications anymore. Esri will do it all with configurable apps. We can't begin to buy that idea without being able to do these types of things.
Absolutely agree that the option to create a selection set from the query widget would be very useful as the resulting selection can then be used by other widgets. After all, this is how the query functionality generally works in the desktop apps.
Wow. I'm relatively new to Experience Builder (just under two weeks of digging into it), and I've already bumped against this SERIOUS limitation. Please ESRI - this needs to be rectified as soon as possible. We run the risk of alienating a LOT of our users without this functionality.
Spent several hours yesterday trying to do exactly this, assuming I was just doing something wrong in the configuration. My end-users wouldn't be able to get their heads around any kind of multi-widget workaround, so it needs to all be in one widget. The query widget is doing *something* when it's able to highlight features on the map and show them in a list, so surely converting this to be an actual selection is do-able?
@Jianxia , do you know if this request is in the roadmap at all? I am encountering this limitation migrating from WAB to EB.
Here's my use case:
I have a map widget in which the user can click on features to get a pop-up. For better accessibility and for people who would just rather view a list of features than interact with the map, I also have a query widget that when run, shows the same information as the map pop-up.
I would like to be able to track which features users are viewing information for, which I think means being able to pass the user's data selection to the URL. I know this is possible, but the snag is that it's not possible to configure the query widget to select all records that it creates at runtime. The result is that I could track which features users using the map select, but not the features users using the query widget "select" (create).
A workaround that might seem appropriate at first glance is using the select widget combined with a feature info widget. The problem with this is that the UI is SO much less intuitive (have to click on an unlabeled button to show the attribute filter, then click on the slider to enable the filter). The audience for this experience is going to be the public, so it really can't be complicated.
