EB Query Widget: allow spatial filters to act on multiple query layers at once
785
12-15-2022 09:56 AM
Status: Open
Labels (2)
TaraHaynes
Currently, you can get results for one query layer within a defined area using the query widget. However, if you want results for multiple query layers, you need to do so layer by layer, and you can't carry the same drawn shape between those layers.
I would like to have the option to apply spatial filters (filter layers, drawn shapes, or map extent) to all desired query layers at once and generate an output showing the results of all queries. For example:
Query Layers: nest site points, stream network lines, land use polygons
Filter Layer: custom AOI
1. Draw custom AOI
2. Select Query Layers to act on, eg: Nest Sites & Land Use
3. Return results for selected query layers within custom AOI
