Copy a page from one ExpBuilder to another (or import page)
11214
9
05-05-2021 09:16 AM
Status: Open
JayJohnsonWashoeCounty
It would be very useful to copy an ExpBuilder page from one project to another.
I have an existing page that has extensive filters set up.  It would be useful to copy this to another ExpBuilder project that has the same data source.  Or put another way, I'd like to "import" a page from one project to another.
Tags (1)
9 Comments
BrittanyBurson
I wish I had more upvotes to give for this. I would also love to see some of the great home page/sub page layouts available in all the various templates available a la carte in the "Add page" selection.
Thank you for posting this Idea.
JonathanMcDougall
I think this would be very welcomed, so thumbs up from me. I do have another suggestion, @JayJohnsonWashoeCounty  maybe could be added to your post? It would be good to be able to copy widgets across pages too - almost using something like the pending list just making a "copied widget list" available across all experience pages.
Melanie_Kohls
The Copied Widget list idea is great, and exactly what I was looking for when I wound up on this Ideas page. I have several layout items and widgets that I created on one page and want to copy to a second page.
ArianaMo1912
That would be a really great idea! I really need this!
Woodpeckerus
Great idea!
In the meantime, you can probably embed the Experience builder page into your current Experience you are building.
SStopyak_BruceHarris
Being able to copy pages from one experience to another would be great! I can't believe this functionality doesn't exit!
xingchenc
please consider this function.
konsta_kuorikoski
Example of real-world use for this feature. We have several apps (of which some are at some point combined under one). Links to these apps get spread wide after initial launch. Doing any kind of major overhaul on design there are are choices. Do same single actions to each app one-by-one to achieve consistent UI/UX while preserving existing direct link to app. Or build one template and use that as base for all app, changing all links and causing more work to other departments and end-users.
Allowing to copy or export/import page and widgets would solve this problem almost completely. Ofc there would still be minor fixes needed if datasources differ. But gains for getting almost equal UI/UX with no change to link/ID are much greater in comparison.
MarkGo
Bummed to see that no progress has been made on this since 2021.
I'm working on creating a "master app" for a department at my org, and I would love to clone an experience I have already built as a section of this new app, but with the ability to make edits (so embedding doesn't quite meet that goal).
Having some sort of global "pending list" as was suggested could work, or simply importing the other experience into the current experience.
