Change View when Selection is made on Map Widget
913
11-23-2023 04:41 AM
Status: Open
Labels (2)
RobertAnderson3
MVP Regular Contributor
I'm trying to rebuild the Shortlist template from Story Maps as it has been deprecated. There's a handful of issues trying to match it but in my current build the big issue I'm finding is that selecting a feature on the map cannot open the Feature Info view.
I'm using the Views widget in the side column for the list and the feature info, however when you select a feature on the map all it seems to be able to do is select the item on the list, the map widget does not have the ability to change the view (or open a window if I want to try it that way).
This link needs to be added to help replace one of the most useful public information sharing story maps.
1 Comment
RobertAnderson3
This functionality is still lacking, however I just wanted to add that I reached out to Esri and opened an enhancement request for this topic if anyone is interested in adding their name and support to it that way.
ENH-000162330Provide the Set link option in Map widget and allow owner to direct users to another window in Experience Builder
