Real-world Problem: First responders are working on an Urban Search & Rescue team during a tornado or flooding event. To organize their search operations, they use a Web AppBuilder product called Intel Manager within SAR Common Operating Platform (SARCOP) to quickly create search segments and monitor what has been searched. By using the Batch Attribute Editor widget within Web AppBuilder, first responders can quickly select numerous points that they previously assigned as "Needs to be searched" and change this attribute to "Complete - No Follow-Up Needed." This workflow is critical to minimize time spent searching for disaster victims and reduce duplication of effort. Many teams work within the same app. The ability to filter to a specific attribute (e.g., Team Name) while selecting for a batch attribute edit is also significant to reduce mistakes and streamline the workflow.
The screenshot below shows an example incident within SARCOP with about 60 points.
See below, the user can choose to select a group of points by drawing a freehand polygon.
In the screenshot below, the points in the selection polygon were selected and the user can update attributes for the group of points all at one time.
Audience: First Responders, Urban Search & Rescue Team Members,
Technical Problem: Batch Attribute Editor widget is not available within Experience Builder. We are migrating these apps from Web AppBuilder to Experience Builder in anticipation of the deprecation.
Potential Solution: Ability to edit attributes using a batch selection within Experience Builder, similar to Batch Attribute Editor widget from Web AppBuilder. Batch editing attributes without the need to utilize a separate ArcGIS product is important to this workflow because our users are often working in time sensitive environment on a tablet or mobile and might not have any prior GIS experience outside of our app SARCOP.
@AlixVezina Are there any updates on the timeline for batch editing in attribute mode? In the meantime, are there any workarounds you might recommend to implement batch editing in experience builder without adding the ability to edit geometry / interact with the map? Thanks!
@DannyLawlor , this is currently planned for the upcoming October release. Otherwise, it will make it in the first release of 2026.
A workaround may be to hide the Map on the page and use another widget to select features, such as the List or Tables widgets which also support multi-select.
For e.g. below, I hid the map behind the Table widget. Note that I don't recommend this as a best practice, maybe more like as a "hack"...
I cannot find Batch Editing in Experience Builder or get Web Editor to load any layers in enterprise 11.5. Very frustrating ESRI
@ClintDickerson that's expected as batch editing was not available in the Edit widget in ArcGIS Enterprise (11.5) . You could alternatively install and use Experience Builder developer edition, which includes batch editing in the Editor widget. I used to be intimidated by the dev edition, but after I took some time to read and follow the steps in the link, it wasn't so bad!
